‎03-05-2021 11:55 AM
Hello! So I'm working on a comprehensive project for my computer tech course and what I am trying to do is create basically a who said it quiz in labview. The user is prompted with a quote display after pressing start and has to attempt to guess which character it is until they get it right. I can't figure out how to let someone type an answer while the VI is running or to have a button for them to press with the character's name as their choice. I just need help getting it up and running structurally. This is the first time in the course that I've been excited about an assignment since we got to come up with this one and I'll actually have my friends be test subjects because the data has to be written to an excel file where I can collect the results and insert them into a histogram. Aditionally, I am trying to make it display the picture of the character and a sound bit of the actual quote when they get it right. I have everything wired to show the pictures and I'm sure I can do the sound file but I need help with the actual guessing game VI part. Any help would be greatly appreciated.
‎03-05-2021 12:16 PM
So where are you stuck?
What have you started with?
Without a VI for us to look at, how do you expect us to be able to help?
It sounds like you don't have a LabVIEW problem yet, but a program logic problem.
Have you written down with some pseudo code or flowchart what the program should be doing logically?
‎03-05-2021 12:58 PM
this is what I'm working with right now. Attempting to use a case structure to discern between character quotes. I have a function over to the side that will allow me to force the VI to wait for the user's input on the front panel but it won't connect to anything I have so far. Ideally, when the message is displayed, the subject would be able to click okay to clear the message and then press one of the buttons with the characters name (shown here as boolean)
‎03-05-2021
01:05 PM
- last edited on
‎10-09-2025
02:45 PM
by
Content Cleaner
I highly recommend looking into a State Machine architecture. One of those states can contain an Event Structure where you wait for button presses and react accordingly.
‎03-05-2021 02:01 PM
Okay.. so I've read that whole article a few times through and I'm not sure what is not clicking or why but how do you build it? Because its not just a function on the control panel... or if it is I can't find it
‎03-05-2021 02:09 PM
I figured out how to create this, nevermind. But we haven't really worked with these so I'm not sure how to make it work with this VI
‎03-05-2021 03:01 PM
Think carefully through the order of operations of your program. You will see steps that much be completed. Generally speaking, each of those steps is a state in the state machine. Use shift registers to maintain which state to call next and the variables in the system.
‎03-05-2021 03:14 PM
I understand how to use the shift registers with the state machine. I am currently trying to build the single run before I put in the continous loop and this is where I have gotten to but I can't seem to wire it to where it will display the image...? I'm able to see the first quote and choose the character.
‎03-05-2021 04:24 PM
What exactly do you mean by "I can't seem to wire it to where it will display the image". I see you have a file path and a Read JPEG and picture in the case structure.
But I can tell your VI is broken because the tunnel executing that case structure doesn't have a boolean value wired for all cases.
When your run arrow is broken like yours must be in the situation, click on it and investigate the errors.
‎03-06-2021 09:31 AM
Alright guys, the guessing game works but I'm having issues wiring it to write it to an excel file. Here's the block diagram.
Its a stacked flat sequence
