Help with Continuous acquisition and logging project template
Okay I have decided I am going to attempt to figure this out. This project template was recomended in an eirler post http://forums.ni.com/t5/LabVIEW/Help-with-freeze-up/m-p/2636739#M788003
So bear with me here as I ask a bunch of questions that I probably would already know if I had any formal Lab View training.
Lets start with the Acquisition loop I inserted the VI for my instrument but now I have a bad wire leading to the Notifier(?) and Enqueue Vi's. My instrument Vi outputs a numeric array these require some sort of cluster input. I tried making a cluster constant and using bundle but this type of cluster does not bundle or unbundle?
=== Engineer Ambiguously ===
Message 1 of 15
(3,216 Views)
If you turn on context help (Ctrl-h) and hover over the notifier wire, it will tell you what type of data it expects.
Or disconnect the "notification" input, right click and "create constant".
Message 2 of 15
(3,210 Views)
Oh, thanks. I see it contains Array (1D array of) dosen't say what of, and a Waveform (Waveform DBL)
So my instrument VI outputs an numeric array of measurments, how to I turn that into something that works with this Notifier?
Message 3 of 15
(3,202 Views)
Hi RTSLVU,
That's a 1D-Array of Waveform(DBL)- note that "Waveform" is inset rather than inline with "Array".
If you're planning on working exclusively with arrays of DBL, you'll probably want to change the data type used to initialize the queue and notifier rather than converting the numeric array to a waveform.
Tom L.
Message 4 of 15
(3,195 Views)
Don't be afraid to go up to the main vi and change the notifier's datatype to match your vi's output
"Should be" isn't "Is" -Jay
Message 5 of 15
(3,191 Views)
@0utlaw wrote:
Hi RTSLVU,
I opened the constatns that initilze the Queue and Notifier and they contain a time stamp, a numeric array, a numeric constant, and a variant.
But it  changes to just a waveform in the Accuision vi
Message 6 of 15
(3,188 Views)
Hi RTSLVU,
A Waveform is actually a cluster containing those data types you listed- initial time, delta t, values, and a waveform variant that can store various attributes such as channel names- note the cluster (pink) border within the array. These documents have more information on using waveforms:
KnowledgeBase: Using the Waveform Data Type in LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8qkSAC&l=en-US
LabVIEW Help: Accessing Waveform Attributes
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/get-waveform-attribute.html
Hope that helps!
Tom L.
Message 7 of 15
(3,181 Views)
Okay I see now I need to manually replace the Data Notifier and Data Queue input constant with one containing just the data type I need in every single VI.
Curse them for not making this a typedef!Smiley Mad
Message 8 of 15
(3,178 Views)
Nope damnit that won't work either it is still broken in the Acquire.vi.
I am going to have to figure out how to make the origonal waveform cluster work.
Message 9 of 15
(3,168 Views)
Hey,  If it was easy we wouldn't earn all the money they pay us to learn this stuff.
I'm pleased to see you working through it though!
Message 10 of 15
(3,156 Views)
