Help needed in adding custom About box in built application in LabVIEW 2009
Can anyone please help me add custom About box in built application in LabVIEW 2009? I had successfully built my application in labview 8.6, 8.5 and 8.2 before to include custom About box. However, when I tried the same method in LabVIEW 2009, it only showed LabVIEW 2009 About box rather than my custom About box.
Here is what I did:
1) Wrote an "About Application.vi" in the built VI folder;
2) Included this "About Application.vi" in the "Always Included" section of Source Files in Application Build;
3) Built the application;
4) Ran the built application, the About box showed only LabVIEW 2009 about (attached a picture).
You can see that on the upper left corner of the picture, there is my custom icon.
Your help is greatly appreciated,
Cathy
(2,608 Views)
Place a checkmark in the "Use LabVIEW 8.x File Layout" box under the Advanced Category of your Build Specification.
(2,575 Views)
Accepted by topic author Cathymin
Thank you Christian. To place a checkmark in the "Use LabVIEW 8.x File Layout" box did not work. I found a solution though that LabVIEW 2009 has this inherent problem of not showing custom About box, and it has f2 patch to fix this problem.
Cathy
(2,535 Views)
Ah ok! Maybe I had this batch allready installed on the system I was testing this behaviour.
Could you please post the link to this KB here for other users.
Christian
(2,525 Views)
Here is the link to download LabVIEW 2009 f2 patch:
http://digital.ni.com/public.nsf/websearch/C3F88F3596A164AD86257647006FB022?OpenDocument
Thanks for the help,
(2,510 Views)
