Help needed in Custom scale for Daqmx
While using custom scale of Table for voltage acquisition and scaling up in NI9220 ,  facing an issue in empty string,  I have attached the log file, while testing using a separate Test VI it causes no error, while implementing the same in main code cause this empty string error, used scale name in constant too, below  screenshot is actual code ,while running it cause error -200212,but made sure there is a string incoming and no duplicate name,  tried to clear this error and  got another error this below
(601 Views)
Accepted by topic author KAVIN_GOVINDARAJ
Hi Kavin,
You create a new scale using the CreateScale function, but you never wire this specific scale to the CreateVirtualChannel function!
Instead you set the CreateVirtualChannel to use a custom scale, but you leave the scale input unwired…
(597 Views)
It worked,thank you
(586 Views)
