"H.J. Beestermoeller" wrote:
> Hi Brett,
> could it be, that you wired the "source element" of all "bundle by name"
> VIs with only ONE source? In this case all bundles take the same source
> cluster and write only the new elements in relation to this source. I
> think this is what you see.
> To avoid this, just take the output of the first "bundle by name" as
> input for "source element" of the second bundle and so on.
> I hope I understood you right.
> Hans Joerg
> "Brett L. Moore" schrieb:
> > Hi,
> > I am using LabView 5.1 and am attempting to sequentially fill a data
> > structure. I am reading a config file and one-by-one filling the
> > entries of a cluster of clusters (called Data).
> > Data is global and I am usin
g Bundle-By-Name to load up one of the
> > sub-clusters (Bundle-By-Name is wired to a read version of Data and a
> > write version of Data). At each load operation, I provide
> > Bundle-By-Name with only the element being filled. However, when the
> > second or third fill operation occurs, the previously filled entries
> > of Data are zeroed out.
> > I can workaround this by filling the cluster in all at once - for a
> > bit. The next set of entries to be loaded is a dynamically-sized
> > array that *must* be filled sequentially at run-time.
> > I need a method of writing to a single element in the sub-cluster
> > without disturbing the contents of any of the other data elements.
> > Any ideas or better ways? Thanks in advance!
> > Brett
The possible way , is to study LabVIEW data storage format, flatten your
"DATA" structure and replace/fill the part of desired flattened binary
string. Rather fast and effective. You just need a pointer to your value
in a data stru
cture and it's length.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
