Dear Sirs:
(I'm using LabView 6. I guess the solution is different for 6.1)
Currently I have created an array of Boolean RefNums (which point to many, many buttons). When I need to know when any (and which) of the buttons was pressed I just compare every element on the array with the constant TRUE. It fact, as the array is built from RefNums, I should compare the VALUE from the Property Node.
The problem here is that the Property Node for this type of Boolean is a LV Variant, and I need to compare this with a TRUE/FALSE value.
I tried to convert the TRUE constant to a LV variant and visc. But nothing works... I always get that none of the buttons was pressed.
Here it co
mes the question: "How can I compare the value of a Property Node for a Boolean (Button) with a TRUE (or False) constant?"
BTW, maybe I should explain why I'm using RefNums instead of the direct values: As my project requires tons of buttons, I would preffer using RefNums to refer to them. (I.E. I could use a single VI that takes the RefNum and formats the button to hide it for certain users).
I have enclosed a VI that contains what I've achieved until now, which is nothing
😉I appreciate your time and help.
JAVIER VIDAL
Mauricio Vidal
VIDAL & ASTUDILLO Ltda.
http://www.vidalastudillo.com
