07-16-2018 12:53 PM
I'm looking for an example of how I can use clusters in this situation, not having much luck.
07-23-2018 02:38 PM
So with the help of the community here's what I have so far.
I'm running into some errors I don't understand and there's a cluster problem I'm not sure how to solve. "you have connected two clusters of different types, cluster of 9 elements conflicts with cluster of 16" I thought that this was an array to a cluster.
The other error has something to do with the (control index) not having an indicator?
VI attached
07-23-2018 03:14 PM
Ok, found out you can right click and set how many elements in the cluster. Changed the default 9 to 16 and that appears to have fixed that issue.
But this other one I'm not sure about so I'll start another thread.
