Help a Newbie with writing time and date to Measurement File
I need help with taking data and showing current time and date on both a chart and writing it to a measurement file.
Essentially I am taking in data from an encoder that outputs data in amps. From here I taking that output current and converting it to a position value in inches. Then calculating velocity which would be outputted on a chart. However, I can't seem to show the current date and time. This VI is running separately over the network. I am using a NI 9207 module on a CompactRIO-9045
I have attached the Vi I am using which is on LabVIEW 2020.
Any assistance would be appreciated and since I am a newbie I might not have given you all the information you might need to help me but I can provide more if needed.
Message 1 of 9
(249 Views)
Your VI is missing.
Message 2 of 9
(236 Views)
Sorry I thought I attached it.
Message 3 of 9
(210 Views)
Hi AverageJoe,
Technical solution to your question: convert the scalar FeedRate value into a waveform, then display the waveform in your chart. The chart will now allow to display timestamps on the x axis…
Your really should cleanup the VI:
  • no sequence structure needed
  • no need for ExpressVIs just to calculate some simple formulas
  • why do you set a sample rate in your DAQmx task, when you limit the iteration speed of the while loop using a wait function?
  • why do you read "N samples" when you only use one single sample per iteration???
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 4 of 9
(183 Views)
Thank you for the help.
Do you know a good way to save this information to the measurement file. I've been trying to find a way for it to save the time stamps as well as the data in like lets say 2 columns and have it presented nicely.
Any assistance would be great
Message 5 of 9
(142 Views)
'Get Date/Time String' or 'Format into string' (if you want more control) will convert a timestamp to a string that you can write.
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 6 of 9
(134 Views)
How is that parameter pass through the write to measurement file express VI. Any help would be appreciated
Message 7 of 9
(121 Views)
Hi Joe,
Then you need to provide your data as two columns (aka 2D array). Right now you only save a 1D array, resulting in just one columns…
Judging from your VI you should take the "Training resources" to learn LabVIEW basics (like data handling with correct datatypes)!
Message 8 of 9
(115 Views)
Yes again I'm still learning and I believe I found some way of making it play nice. Thanks for the training resources.
Here is what I have after some time making my own revisions.
Let me know what you think.
Message 9 of 9
(92 Views)
