07-01-2009 04:50 PM
07-06-2009 02:38 PM
Good Afternoon tia sal22,
Right-click the x-axis and select Properties. Then use the Display Format tab to choose Absolute or Relative Time as the x-axis Type.
I see a Fourier Transform and an Inverse Fourier Transform, one after the other. Do you normally have some processing between the two of them that you removed for clarity on the forum?
What kind of shift are you expecting to see on the graph? The way it is currently programmed, you are not changing anything in the frequency domain, you are simply changing the spacing between the points.
I think your steps 1-5 are correct, but question the implementation of #3. If you want to perform a change in the frequency domain, may frequency be a more appropriate x-axis than time?
07-06-2009 02:45 PM
I'm open to all suggestions I just could not find an example for doing a frequency shift/pitch shift with labview 8.5 So I was trying
to piece different things that I found online. If you have an example of doing pitch shift/frequency shift using labview 8.5 please let me know.
tia sal22
07-06-2009 02:49 PM
This is where I got an example for the frequency shift but I guess it doesn't work the way I need it too.
http://forums.ni.com/ni/board/message?board.id=170&message.id=379272&query.id=710943#M379272
07-07-2009 02:09 AM
Hi tia sal22,
The link you pasted above is the usual way to shift the frequency. If it doesn't work the way you need it to, you may want to pitch shift the signal. Here is an article describing using labview to do the real time pitch shifting: http://zone.ni.com/devzone/cda/epd/p/id/6219
Since the code is written in LV 8.6.1, if it is what you want, I can make it LV 8.5.
Let me know if this is the right solution or not.
Mac
07-07-2009 08:06 AM
Thanks that might help.....but I think it also requires LabVIEW Advanced Signal Processing Toolkit
tia sal22
07-07-2009 09:16 PM
That's right. The Advanced Signal Processing Toolkit is required in this case.
Mac
