Hello! Couldn't found header file extcode.h in LabVIEW 6i
Hello! At the monent I try to use a cluster from LabVIEW 6i to get Data from VC ++ dll. I knew that I need the header file extcode.h. I could found it at directory of LabVIEW 6i.
(3,045 Views)
I found one here "C:\Program Files\National Instruments\LabVIEW 6.1\cintools\extcode.h".
You'll find it in attachment.
Maybe you forgot to install the CIN tool when you installed LabVIEW 6.1 ?
I hope it will help you.
(3,045 Views)
Thanks for answer so soon. The Problem is I couldn't found cin tools on the disc. I have look everywhere. I use LabVIEW 6.0.1 I think this is equal to 6i.
(3,045 Views)
I use LabVIEW 6.1 Professional Development Suite but I still belong the "old" CD of LabVIEW 6.0 PDS.
I made the following test with this "old" CD:
When you install LabVIEW, choose Custom installation. In the feature selection tree you should find "CIN Tools" under "National Instruments-->LabVIEW". Click on it and choose "Will be installed on local hard disk".
It should work.
(3,045 Views)
Thanks for all and have a nice weekend! Jens
(3,045 Views)
