Having trouble with Lecroy 2373 Memory Lookup Unit
I am writing a LabView 5.1.1 program for the Lecroy 2373 Memory Lookup unit. I am using the KS3988 CAMAC controller and the KS3988 VIs that go along with it.
I can load and then read the CCR of the MLU successfully.
I can NOT, however, load or read from the CAR, I think. And I can not load or read words to the addres specified by the CAR.
I am reading the manual for this device.
Is there anyone out there who has experience with this device?
Note: I had to change the original read VI of the KS3988 VIs since they do not work otherwise.
Thanks.
-Kazem
(2,209 Views)
I just figured out the problem.
Not all CAMAC crates have the +/- 12 V pin assignment. The status byte, among other things, uses an auxilary -6 V which is supplied by the -12 V pin. The -6 V can be found at pin Y1, or the fourth pin up on the left side of the GPIB slots.
The crate that I have does NOT have 12 V pins. Therefore, the status byte, and things like the Lecroy 2373 Memory Lookup unit DO NOT work.
Being the hack that I am, I wired -6 V of power into my crate, and now everything works. It looks a little dangerous, but it works.
(2,209 Views)
