03-13-2012 09:01 AM - edited 03-13-2012 09:10 AM
Hi...i have one final project.....my project is to design oscilloscope.VI, after i finish draw the block diagram ( i was design using LabVIEW 8.6), First, i was use the real Function Generator to give signal at my oscilloscope.VI. To connect between The Real Function Generator and PC i was use NI cDAQ-9178, and the result is my oscilloscope can display the output and the output waveform is very clear without any problem. Second, i was replace The Function Generator to the Simple Circut electronic such as Amplifier to give signal at my oscilloscope.VI. But the result is that have many noise in waveform and that have one error have display during run this program. Someone can give me idea, advice and solution to me in solve this problem..now i was state my picture and my oscilloscope.vi
03-13-2012 09:31 AM
Did you try any of the suggestions mentioned in the error dialog out?
-CC
03-13-2012 02:35 PM
It should also be pointed out that your question about the error has been asked MANY times before. Did you try a search for the error code? If you had, the very first hit would have been the following KnowledgeBase article:
Why Do I Get Error -200279 from my DAQmx Read VI or Property Node?
