05-13-2014 03:43 PM
I recently downloaded a NIDAQmx driver for LV2009. Afterwards I decided to upgrade to LV2013. I need to be able to use a DAQ Assistant with my USB DAQ 6009 and LV2013. I still have the NI Icon NIDAQ970f0 on my desktop from before. It has a self-extracting archive that will create a new directory on my hard drive and launch the installation of NI-DAQmx9.7.0.. If I click on the icon and do the installation this will work with LV2013, my USB DAQ 6009, and I'll be able to select the use of a DAQ Assistantwhen I need one, right???
Thank you for your time
dunnor
05-13-2014 04:10 PM - edited 05-13-2014 04:11 PM
Hello dunnor,
Compatibility information for the DAQmx driver and all versions of LabVIEW going back to 7.0 can be found here:
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
Based on that table, it appears that you'll need to upgrade to NI-DAQmx 9.7.5 to have support for LabVIEW 2013. If you install 9.7.5 with LabVIEW 2013 development support selected in the installation wizard, you should have access to the tools you described in LabVIEW 2013.
Best Regards,
