Has anyone used Numato Lab Relays with labview ?
I'm considering using  a numato lab SSD Relay USB unit with LabVIEW. I'm looking for reviews/experiences customer support.
Has anyone used this product ? Do they provide good technical/customer  support ?
https://numato.com/product/2-channel-usb-solid-state-relay-module/
Message 1 of 14
(5,657 Views)
Hi RO,
Well, they provide a LabVIEW VI in their "sample code" section!
(It's a rather simple and not "very good" VI, but atleast there's a VI!)
Message 2 of 14
(5,638 Views)
I used the 8 channel USB GPIO some years ago, for a non-critical input button.
Usage was easy enough, so I did not ask for any support. Just open a serial port and send the proper ASCII command to configure and another to read.
Post-sale support was not necessary so far, too.
Paolo
Message 3 of 14
(5,622 Views)
I have used one of their Ethernet boards (32ETHRL001 ) which uses a Telnet interface.  So I made some code to handle the Telnet and used the pretty simple commands that are in the manual.
If using one of their USB devices, I believe it just shows up as a Virtual Serial Port.  Therefore, you just need to send the commands using simple serial port commands, which I think are the same as the Ethernet commands.
The boards themselves worked perfectly.  No complaints.
Message 4 of 14
(5,614 Views)
We've used them some in our place too, mainly the ones with USB connector and virtual serial port.  Our experience has been like others' here -- no complaints, no need for tech support..
-Kevin P
Message 5 of 14
(5,607 Views)
Thanks for your contribution !
Message 6 of 14
(5,602 Views)
Thank you for your opinion !
Message 7 of 14
(5,601 Views)
Thank you !
Message 8 of 14
(5,598 Views)
Yes, I have used them and they are quite simple to implement in LabVIEW, the command set is super simply to use and it accomplishes what it was intended...  I am evaluating using the TCP/IP version of the relay module...
Message 9 of 14
(5,161 Views)
My only hiccup with the TCP version was when making the Telnet connect, some Telnet command codes needed to be handled.  I don't remember the exact commands.  I just replied with an acceptance of all the command codes I received left it there.
Message 10 of 14
(5,148 Views)
