Has anyone use RS232 Bus Speed of 5 Mbaud or higher using LabVIEW or LabWindow/CVI?
Has any one use RS232 speed up to 5 Mega Baud or higher using LabVIEW or LabWindow/CVI?  I can change my hardware if needed.  Right now we're using FTDI cable up to 1 Mega Baud.  Thanks for you help.
Van626
(3,029 Views)
Hi Van626,
While I haven't done that myself, the VISA driver in LabVIEW or LabWindows/CVI won't limit the baud rate. If you have hardware that supports it, then it should be possible. You can read a bit more about this here:
http://digital.ni.com/public.nsf/allkb/D37754FFA24F7C3F86256706005B9BE7?OpenDocument
-Kevin
(2,991 Views)
Thank you Kevin.  I will give that a try.
Van626
(2,975 Views)
