nels and the STC counter buffer? While it SHOULD be immaterial, I'm running this on a G4 PowerMac in Mac OS 9.0.4 . I can't seem to get the counter VI's to work at all! Yet it seems to work when tested in the NI-DAQ Config. Utility. Please advise- Thanks!I had a similar problem using a 6025E card on a PC where I was aquiring data and attempting to count TTL pulses. The AI was fine as usual, but the count was increasing while there was no change at the TTL source, and counting was very inaccurate. I used a separate 6601 counter card to resolve that application, but I was very dissapointed that I could not get the 6025E card to function properly. Did you ever solve your problem?
Al.
