HUGE bug on "Get section names" (Configuration file vi)
@h_iliev wrote:
Unfortunately the original file is gone, but i think i successfully repeat the error. Sins a wild i am using 32bit version of LabView 2014.
Yep, you are seeing this issue: Config file "byte order mark"
Just open the file in a hex editor and you will see 3 extra bytes that are used as the byte order mark.  That is then throwing off the ini file parser.
Message 31 of 31
(616 Views)
