HUGE bug on "Get section names" (Configuration file vi)
@1abvi3w wrote:
I have already had a similar issue where there was a weird hidden character at the beginning of my file (not even shown by notepad++), before the first bracket so labview could not detect the first bracket at the beginning of a line. and everthing was messed up like you describe.
Sounds similar to this: Config file "byte order mark"
Message 11 of 31
(3,074 Views)
I HAVE 0 RESPECT FOR THOSE LIKE YOU.
Looking at Ironman_s post history he seems to be a guy going easily off. I get the impression he really is forced to use LabVIEW even though he doesn't like it…
But then his wording reminds you on those presidential campaigns - and even I (living in good old Europe) get an impression of what's going on in the States! 😄
Message 12 of 31
(3,051 Views)
Ok, good morning guys
Why do you post on this forum? You make noise.
I know why: you just post in order to increment your post count, don't you? maybe you are paid by the number of daily posts, with bonus at 5k, 10k, etc...
1) NO ONE VERIFIED WHAT I STATE.
SHAME ON YOU.
I clearly mentioned the LV version, and what the BUG is, and what the VI is.
You just replied bs.
Thank you! lol
2) MY INI IS FORMATTED CORRECTLY. it is NOT stated ANYWHERE that and INI MUST have a first section comment.
for example:
[Hi there]
[retarded american software programmer]
what is the EXPECTED output of this INI file?
CORRECT: ["Hi there","retarded american software programmer"]
ACTUAL: ["retarded american software programmer"]
another perfect valid example of INI file:
[mono section]
CORRECT: ["mono section"]
ACTUAL: []  (empty array!!!!!!!!! LOOOOOL)
this is because the monkey coder inside NI decided that "the first section is a comment" (it's written on your source code)
ANYWAY, I HAVE FIXED THE CODE by myself.
THIS IS THE QUALITY OF THIS COMMUNITY
THIS IS THE QUALITY OF NATIONAL INSTRUMENT CODER AND SOFTWARE LIBRARIES. this is the second time that NI shipped a BUGGED vi in LV2015 vs 2014 (the other case is the open pdf with browser url)
CONGRATS MAN!
PRINT MORE DOLLARS! 2000->2008-2016 is coming! tic toc tic toc
Message 13 of 31
(2,969 Views)
Hi  Ironman,
you have been ask to provide your INI file (or a qualified example file) - several times.
And you should provide a VI that demonstrates the problem.
All we get from you is  rude behaviour…
When nobody else encounters this problem it is a valid assumption to say the problem is with your INI file!
Message 14 of 31
(2,954 Views)
Since you did not post your ini file or the VI, no one could verify the bug. Shame on you for such an amateur posting. You still have not attached an actual ini file or VI. Nor have you explained what you mean by 2015 sp1 which is not released. Shame on you again. To be taken seriously, you need to be a little more professional.
Message 15 of 31
(2,949 Views)
Congratulations....
While you may have fixed it for your "special", ill-formatted ini file, you probably broke it now for all regular ini files. That's not a viable solution. If you still think there is a real bug in the production VI or documentation, please file a bug report, get a CAR#, and then post a summary here. Keep it to one short paragraph. No wandering off about your world views.
Instead of complaining about the quality of the community here, actively participate and try to improve it. remember (paraphrasing JFK): "Ask not what your community can do for you, ask what you can do for your community". Be part of the solution!
Now all you need is a new keyboard. It seems your caps-lock key gets stuck once in a while. Maybe you spilled some sugary soda and it got sticky. Good luck with that.
Message 16 of 31
(2,950 Views)
While Ironman indeed breaks lots of netiquettes (which is bad), i took the time to make a small test using LV 2015. I cannot see any issue which he describes in his obnoxious wording.
@Ironman: Can you please verify that the attached code works? Best extract the ZIP in a folder called c:\temp\lv\. If not, you have to update the path constant in the VI.
Norbert
Norbert
Expert: Geometry
Message 17 of 31
(2,925 Views)
Is the array showing your results set to Index "1" perhaps, thus meaning that you simply don't see the first element?
Message 18 of 31
(2,889 Views)
for example:
[Hi there]
That's not what I'm getting.  Again, perhaps you should post your actual INI file.
Message 19 of 31
(2,872 Views)
Norbert
I didn't go to those trouble of testing specifically since I use those functions in just about every application I write and never encountered anything that even remotely resembles the behaviour of the OP. That together with the more than rude post and completely unfounded accusations disqualified the entire post fully and immediately for me.
Rolf Kalbermatter  My Blog
Message 20 of 31
(2,848 Views)
