12-12-2022 05:11 AM
I'm trying to open HPF file.
I attached the .VI and the file.
I would also like to know how to read hpf. files faster. It takes almost 5 - 10 minutes to open a file. The file size is usually around 300Mb.
Thank you in advance,
Evyatar
12-12-2022 05:43 AM
Hi Evya,
You forgot the most important parts of the message…
12-19-2022 11:22 PM
I'm sorry, I was sure I did.
Let's try again.
I attached a file that works and one that doesn't work.
My concern is with the amount of channels, is it possible that there are too many?
*The file that doesn't work is not empty for sure or corrupted. I manage to open it with EMGworks and to export to csv.
12-20-2022 08:32 AM
Hi Evya,
unfortunately I don't have that dataplugin installed, so I cannot run your VI…
General suggestion: when attaching files you should use ZIP to compress archives. Using proprietary paid software (aka RAR) instead makes it unusabvle to many people…
