HP4395A Data Aquisition
I've been trying to use the HP4395 Driver for Labview 8 and have run into a problem getting trace data.  I've been able to set up the instrument, set it to run in Network Analyzer mode and most other things like setting the sweep parameters etc...
However, I've not been able to get data off of the machine.  I'm trying to use the "Trace Data 64 Bit Real" function but this seems to either return all 0's or some kind of junk.
Does anyone know if I have to run any other commands before getting the data?
Flobear
(3,559 Views)
I am a little confused about your issue. I cannot seem to find the function "Trace Data 64 Bit Real" please further explain what you are doing and where you obtained this function.
I would also like you to know that this driver is not supported by National Instruments it was created by HP and has not been tested so we are not sure what problems there are. I will try to help you the best that I can.
Regards
Krista S.
Applications Engineering
(3,539 Views)
