HOW TO DRAW THIS VI:NESTED WHILE LOOP
How to do this ?
source is a matrix of 360*100 it is a image
a=[]
i = 0 while i < len(source): j = 0 while j < len(source[0]): a.append(i,j) j += 1 i += 1
Is this correct?
Message 1 of 16
(1,719 Views)
Hi gpt,
@gptshubham595 wrote:
How to do this ?
Start a text editor and type that text…
 i = 0
        j = 0
            MY_FUCTION()
            j += 1
        i += 1
What exactly is the problem? What have you tried?
I would use 2 autoindexing FOR loops and a subVI named "MY_FUCTION".
Why do you need 2 loops to call "MY_FUCTION" 36000 times? From your question that function does NOT depend on i or j…
Message 2 of 16
(1,717 Views)
Accepted by gptshubham595
In LabVIEW we have "auto-indexing" terminals. If you only feed in a 2D array to a for loop, it will run once for each row. If you feed the row into another for loop, it will run once per element, which would be your columns.
Message 3 of 16
(1,716 Views)
I have edited my question, I want to add a bilateral filter over this image. I am confused regarding two nested while loop,
I know how to implement single while loop
I have edited My_FUNCTION to a array insert, means I have coded this but I want to put it inside a loop
Message 4 of 16
(1,708 Views)
Hi gpt,
I am confused regarding two nested while loop, I know how to implement single while loop
Again: use FOR loops with autoindexing inputs!
Place one FOR loop, then place another FOR loop inside the first one to nest them…
Message 5 of 16
(1,694 Views)
is this correct showing i and j?
Message 6 of 16
(1,689 Views)
Did you try to run it to prove it to yourself?
No, you need an auto-indexing tunnel on the array wire going into the inner for loop.
Also, your text code seems incomplete.  The syntax doesn't show if the i+=1 is part of the inner while loop or outside of that.  By indentation, it seems to be outside the inner while loop.  But I don't see any syntax that shows where the steps of the inner while loop end.
Message 7 of 16
(1,679 Views)
I want a value at that i,j index at every iteration but this return an array
even inside the array, I want COLSxROWS, not ROWSxCOLS
means I tried to test this by myself and with a timer but it is not iterating row with cols but I want to iterate with cols with rows
means I want  cols x Rows iteration
1 2 3 4
4 5 6 7
8 9 0 1
4
8
then
2
5
9
Yes "i" is outside the inner while loop
Message 8 of 16
(1,672 Views)
Transpose 2D array before you feed it to your loops.
Also, when you have auto-indexing tunnels, you do not need, and really shouldn't, put a constant on the N terminal of the For Loop.
Message 9 of 16
(1,667 Views)
Welcome to Python, where indenting IS your delineation of code blocks.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 16
(1,657 Views)
