HOW TAKE ARNGE
Dear Sir / Madam,
Dear sir I want to take a range from 1-D data file. Like file having value 0-90, I want to take values which have 0-10, 11-20, 21-30, 31-40, 41-50, 51,60, 61-70,  71-80, and 81-90,  Here I have attached file  image file of results.
Message 1 of 13
(5,791 Views)
Ok, what have you tried?  Sounds to me that you will need a simple FOR loop with a shift register for each bucket.  Use a case structure to add to the proper array when in a certain range (the case structure does take numerics).
Message 2 of 13
(5,778 Views)
Or, a simply use the histogram.vi on the signal analisys palatte.  (Sorry no example I'm ugrading to dev suite 2012 this afternoon)  Crossrulz can you carry that one for me?
"Should be" isn't "Is" -Jay
Message 3 of 13
(5,775 Views)
I don't see how a histogram is going to give him what he wants.  The histogram VIs only give the counts of each bin, not the values that went into a bin.  Or am I missing something?
Message 4 of 13
(5,767 Views)
Just thinking a step ahead.  Why else bin the values?
Message 5 of 13
(5,763 Views)
Here ,,
I have attached a program and file, is it correct?
Message 6 of 13
(5,758 Views)
That looks like it should work.
But to save you a little on the read side, you can right-click on the Read Text File and tell it to read lines.  Then wire -1 to the count in order to read all of the lines.  You can then use a Fractional String to Number converter on the read array to get your 1D array of numbers.
Message 7 of 13
(5,717 Views)
Dear Sir,
Thanks for positive response, please help me a little more,
This program is working fine fine for less range, but for larger ones, like 0-10, 10-20,20-30,,,,,,,,,,,. 350-360, this program makes lost in confusion please suggest me another way to take range form 1-d array file.
Thanks & Regards
Prince.
Message 8 of 13
(5,687 Views)
Sort array. threshold array in an autoindexed loop. mobile again so no example . anyone?
Message 9 of 13
(5,677 Views)
Accepted by topic author Julian_prince
Hi Jeff,
here you go:
I create an array of cluster of array to store 1D arrays of different length in an (kind of root) array...
Message 10 of 13
(5,669 Views)
