mforkner@my-deja.com wrote:
> I need to know exactly what steps are necessary for transferring a
> waveform file from a PC to an AWG2005 Arbitrary Waveform Generator using
> only LabVIEW. I tried to read a wavefrorm from a file into the AWG but
> got errors. I use LabVIEW 5.1 and employed the 488 vi's -- not the
> 488.2 vi's.
> Someone suggested I use the IBWRTF command, but this didn't even work in
> the IBIC program. The IBRDF starts to write a file to the PC from the
> AWG to the path_name\file_name specified on the command line, but
> encounters a time-out no matter how long I set TMO for.
> Any and all suggestions greatly appreciated.
> Thanks,
> Mike Forkner
> Sent via Deja.com http://www.deja.com/
> Share what you know. Learn what you don't.
I used t
he AWG2005 arb a few years back with LV4.0.1 while designing a
maintenance test station. One question I have: Do you need to transfer
actual data, or can you get by with modeling the waveform parametrically?
The approach I used for each waveform was:
1. Build an equation definition locally
2. Transfer the equation definition over the GPIB to the arb mass memory
3. Compile the waveform in mass memory
4. Delete the original equation definition
5. Transfer compiled waveforms to dynamic memory as needed
This approach, if it is acceptable to your application, allows you to
eliminate waveform variability and minimizes the amount of data transferred
over the GPIB interface (which can be enormous for raw data). I remember
briefly flirting with raw data transfers, but I don't think I kept any of my
notes.
Hope this helps,
Jeff Lucas
(for email, remove the 'x')
