thanks. Next time I'll look inside my temp-directory first before rebooting
the PC (rebooting deletes the temp directory in our system).
Fortunately, I was able to reconstruct my program. It was a little bit long
winded but now it works again. I think sending it to NI would have lasted
longer than the two days of work I spent.
Thanks again
Heiko
Greg McKaskle wrote:
>> for a certain reason I had to kill the Labview task via the NT-Task-Manager.>>
Now it seems that my *.llb is corrupted. Thrying to open it, Labview says>>
that it cannot list the llb-content.>> Is there any way to repair my llb
or to extract the vi-files out of it.>> Thanks for any help>> >>The first
thing you may want to do is to look in your temp>directory for
files that
end in .llb and are similar in size>to your LLB. The LV save operation uses
temp files to try>really hard not to lose anything during save. After doing>that,
you may want to run a disk check program and make>sure that your disk directory
structure is OK or correct>it if it needs it. NT is so much better than
earlier versions>of Windows, but corruptions can still occur. You may also>want
to consider using NTFS as the file system format>because it is much less
prone to corruptions.>>Finally, if you don't have a temp file and fixing
the disk>directory system doesn't fix it, you can send it to NI technical>support.
They may be able to salvage some or all of the LLB.>>Greg McKaskle
