HELP!!!!! I have A BIG PROBLEM with TXT file!!!!
Hello there,
as u can see i'm not verey good with labview....:( .
i need to do some work with txt file, with yours help i did some of the work but i'm cant continue , know lets go to the problem.
as you can see in my project i'm read some data from the txt file.now i need a subvi that will read the result of each test and :
make this in a diffrent window.
1)display the result in table, sorted [pass], [fail].
2) display  min value,max value.
3) display avereg.
its look like this:
test name :......
number of pass:....
number of fail:.......
                               pass value|   fail value  |
                                        1              100
                                        1               101
                                         2              500
                                       3                600
                             min value:
                             max value:
                              avereg :
can some one help me with this problem?
Note:
i added the all the project files/
i'm verey verey new to labview.
many thanks to all of u for your help befor.
put the etmw_x.txt in drive c.
regards,
eyal.
Message Edited by Support on 09-15-2005 10:51 AM
(2,215 Views)
It would really help to keep everything in one place!
and in a different thread with the same name:  raed lines from text file execution speed is unreasonable ---the subvi and txt file
Now it started again here: need help read txt file  and here: need help with txt files.
We're still discussion basically the same issues (parsing a text file) again here.
Please don't start a new thread every other day, but continue in the existing thread. 🙂
(2,196 Views)
