Rick, thanks alot.
Yes, each tray will have a unique start time.
This is how the process works:
When a tray leaves the assembly machine it is inspected for defects.
The operator/inspector has 45 min to put the tray(manually) in an
oven.
It takes about 12 min to complete one tray thru the assembly machine
and another 3-4 min to inspect. Since we have only so many ovens we
save up trays till we will have a full oven. Sometimes, like if the
assembly machine is down, the trays might sit out too long(or if an
operator is goofing off, but that NEVER happens). Thats the reason
for the alarm.
Thanks for the help, I took the Basics 1 & 2 in May but haven't had
any chance to use it at work. Like most thing left sitting, I'm a
little rusty.
On Tue, 14 Sep 1999 09:50:
24 -0400, Rick Nelson
wrote:
>I'm working on your VI now... just to make sure of what I'm doing....
>You have 5 items which have start times (each start time is unique,
>yes?), and when you see them enter the oven, you hit the switch (making
>sure that Input Tray Number is on the right setting). All the while
>there is a counter, and if any of the trays' time on the track is over 45
>minutes (2700 seconds), an alarm sounds.
>Is this correct? In this case you'll want an array of clusters.
>Array of 5 elements
> Cluster of 3 elements
> Time Start (U32)
> Time End (U32)
> In oven? (Boolean)
>Rick
