02-24-2006 05:13 PM
02-27-2006 03:48 AM
Without digging into specs ....
You have a 50ch DMM with 50kHz scanrate?
02-28-2006 02:16 AM
Hi CrukZ,
I am NOT a "hardware" person, but recently researched this subject and (with a hardware person) built a shorts-test station. One solution that I/we considered was to use an analog DAQ board. We'd have put some voltage - say 5V - on a buss, then branched off the buss with 50 individual high-precision resistors - one to each testpoint (one input goes straight to the ?V buss). The DAQ board does a single-ended voltage measurement at each test-point - the mid-point of a voltage-divider - and use the measured voltage to calculate current and/so resistance. Two 1.25MHz DAQ boards (triggered together), at 25-channels each, would get the DAQ-rate you're after.
You'd have to play with the test-voltage and resistor choices depending on the current/voltage specs of your device. I think the closer the series resistor matches expected DUT resistance, the better it is for the calcs, but then really low resistance means higher current so it's "a balancing act". The more expected resistance varies, the worse it is for the calcs.
In our case, the tested circuits included diodes and current didN'T change linearly with test-voltage. However, we successfully emulated a hand-held Fluke DMM @1.2V on the 400 ohm scale. Done-deal!
BTW, I won't feel bad if someone describes why this is a terrible idea.
I am NOT a hardware guy person
02-28-2006 11:40 AM
