Hüllkurvenanalyse envelope curve analysis
Hey,
ich baue einen Versuchsaufbau auf, bei dem Vibrationen analysiert werden sollen. Dazu soll Labview benutzt werden.
Die FFT steht soweit, nur frage ich mich jetzt warum ich noch eine Hüllkurvenanalyse mit einbauen soll, wenn ja wie geht das und wo baut man das in das VI ein?!? Kann mir das bitte jemand erklären, meine Kenntnisse mit Labview sind schlecht.
Der Unterschied ist für mich nicht ganz ersichtlich. Die FFT ist ein Werkzeug um die Hüllkurvenanalyse darzustellen, hätte ich jetzt gedacht...
Danke für eure Hilfe!
Message 1 of 10
(1,800 Views)
Hi Gregory,
when you are posting in an English speaking forum you should try to write in English.
Or stick with the German LabVIEW Forum! (In case you are the same user as in the linked thread then you should have had 6 weeks to learn LabVIEW!)
You may search for "hilbert transform" here in the NI forum to find VIs like the one I attached. (Sorry, don't know it's origin anymore.)
Why are you uncertain on implementing the "envelope analysis"? Either its part of your requirement sheet - or it isn't…
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 2 of 10
(1,767 Views)
Hi Gerd,
i just asked myself, cuz i didnt get/understand the real difference between the VI how it works now with the FFT and adding the envelope curve analysis. What is the added value then?
Message 3 of 10
(1,754 Views)
Hi Gregory,
could you attach your VI converted for LV2014?
You need to decide this on your own, based on your requirements!
When you can analyze the envelope line already then there is not much improvement from adding an alternative method…
Message 4 of 10
(1,751 Views)
hm, okay. so i think i have to test it with my experiment if i can see there a big difference.
another point to make the vi looking good:
as you can see there are 5 windows. how to get them one behind the other, like it is in the browser from firefox, google or the internet explorer?
Thank you 🙂
Message 5 of 10
(1,745 Views)
Hi Gregory,
Well, there are 5 graphs in one window… 🙂
As is done in FF, Chrome or IE: they use tabs!
Use a tab control and put each graph in its own tab.
Well, then you should clean up the BD too! 😄
Message 6 of 10
(1,739 Views)
Hi Gerd
How to do this?
BD
What does it mean?
Message 7 of 10
(1,732 Views)
Hi gregory,
- controls are FP (=front panel) elements sorted into several palettes
- a "tab control" is found in the "containers" element palette. You can create as many tabs as you need in your tab control
- BD = block diagram
Message 8 of 10
(1,729 Views)
Ok, thanks Gerd!
I got it with the Tabs!
But still dont know how to make a envelope curve analysis 😞
Message 9 of 10
(1,711 Views)
Hi Gregory,
Yesterday you said you have a working solution.
Now you don't have it? Even with my example VI?
When you want your own algorithm: Wikipedia explains it too…
Message 10 of 10
(1,704 Views)
