Gw insteck PSP - 603 power supply.
Hello my name is Andrei  ,
 I have a power supply model PSP -603 . I have set the output "on: and the lock option "on" but when I restart the power supply this two option goes off. I repeat this many times but with the same result.
Thank you.
(2,109 Views)
Hi Andrei,
when you "restart" (switch off and on) an external device it (most often) goes back to default settings…
Does the device manufacturer state in the manual it will keep the user settings even after a power switch cycle?
(2,102 Views)
For good reason power supply should go back to disable output when power on.
Imagine what can burn, destroy or kill if someone power it up with output activated.
Safety First!!!
Make your software to control the output when it is desired...
Benoit
(2,089 Views)
