Guide me how to acquire and subsequently generate sound signal? (parameters to be controlled : time lag between generated and acquired signal, amplification)
The above mentioned task is supposed to be used for active control of sound. ie.
sound is produced in an open-open tube
at one end microphone is placed to pick up the sound
at the other end speaker is placed to generate the "ANTI- SOUND".(sound with appropriate with phase lag annd amplificaion)
sound friquency ranges between 200-1000 Hz.
pci6025E
133 Mhz processor
win98
(2,341 Views)
Hello;
You need to be more specific about your questions. We definitely need more information to help you better.
Regards
Filipe
(2,341 Views)
Guide me how to acquire and subsequently generate sound signal? (parameters to be controlled : time lag between generated and acquired signal, amplification)"
"The above mentioned task is supposed to be used for active control of sound. ie.
at the other end speaker is placed to generate the "ANTI- SOUND".(sound with appropriate with phase lag and amplificaion)
hi,
I think I have included all the details. e.g. card to be used computer processor speed etc. neway here I mention them once again.
sound frequency ranges between 200-1000 Hz.
pci6025E 0.2 MHz
2 pressure trancducers
133 Mhz processor
win98"
If this is not suficient, it would be nice if yo
u ask any particlar information.
ps: I am supposed to generate the same aquired signal with the time lag of 0.5 to 1 milliseconds. Hence I am bothered about the response time of LABView. Will it be almost real time in the current configuration. I am ready to change my CPU rocessor.
(2,341 Views)
