Group 3folders in a single folder and save it in a new path
Hello guys,
A simplified example of my concern:
I have 3 folders (RECORDING , RECORDING 2, RECORDING 3) containing files.
My application is to be deployed with a plug-in and I now need to group these 3 folders together and put them in a new folder called RECORDING PLUGIN which will be registered in the plugin path (Data Path plugin ) see vi below.
How can I group these 3 folders into a single folder please?
Thanks you
(1,682 Views)
Accepted by topic author Ngouda
The question you ask is simple, but the example code you show is more complex.  Let me try to give you a simple answer.
Given:  Three folders, whose paths you know and can group into an "Array of Folder Paths", need to be moved (or copied -- I'm going with "moved" as it makes the situation simpler, only one set of folders-of-files to worry about, but changing it to "copied" should be obvious and trivial) to another folder, whose path you also know (and does not "intersect" the three soon-to-be sub-folders).
Given you are processing elements of an Array, drop down a For Loop and wire the Array of Folder Paths into it through the default Indexing Tunnel.  This will give you, one at a time, the folders to be moved/copied.  Also bring in the wire from the Folder-of-Folders through a Shift Register.
Inside the For Loop, drop a Move function from the File "Advanced File Functions" sub-Palette.  Read its Help and wire the two inputs to it.  Note where the two inputs and one output go.  [If you wanted to Copy, instead of Move, the input Folders, you'd substitute "Copy" for "Move", obviously].
The output Path will be the Folder you specified to contain the three Inputs Folders, and will contain the three Input Folders.  Very simple, all done.
(1,636 Views)
Hi @,
Thanks you for fiur reply.
That works fine now.
(1,585 Views)
