Graying out arrays within array of clusters.
I have an Array of clusters, and the cluster contains an array I am trying to gray out the Array within the cluster  when internal array has data it is grayed out as I want but when the internal array is empty it is not grayed out is there a way to correct this without adding data to the internal arrays?
See attached Picture
(3,224 Views)
That really sounds weird. Can you attach a very small array containing your array of clusters?
(preferably make the current values the default as shown in your earlier image)
EDIT:
Nevermind: OK, I was able to reproduce this. Seems like a bug. Please report it. In the mean time you could initialize the array with zeroes to keep it disabled).
Seems it need to be at least an array within a cluster within an array....
(3,210 Views)
(3,178 Views)
Hi Tsb/Altenbach,
Thanks for bringing this to our attention. This was reported to R&D (#396090) for further investigation. As mentioned earlier, a possible workaround would be to initialize the array with zeroes. Thanks for the feedback!
Doug W
(3,130 Views)
