Grayed out block diagram
I have a problem in opening a vi (which is not written by me), I am not able to open the block diagram of the vi,
am sure that it is not password protected!
even the vi properties option is not available!
not even run and stop buttons also visible in this vi
What could be the reason for the following problems, any suggestions to open the block diagram?
(4,062 Views)
Could you post the VI?  You did not show anything useful.
But some random thoughts on what the issue could potentially be:
1. File is set to Read Only
2. The VI was saved with the block diagram removed
GCentral
(4,048 Views)
Accepted by tanveer1993
This is a "Globals" vi. It is intended to host global variables (controls that can be accessed by any vi in your project).
As such, it has no block diagram, because there is no associated executable code.
To use this vi, pick the vi icon and drop it to another vi's block diagram, then click on the created global and select the one you need.
Paolo
(4,047 Views)
(4,023 Views)
Ya, it seems like a global as you said, am confused, as I don't know how to use it?
(4,020 Views)
Search for Global Variable in the LabVIEW help.
Paolo
(4,012 Views)
And then go watch this: Are Global Variables Truly Evil?
GCentral
(3,996 Views)
