@billko wrote:
@JensG69
Nevertheless both controls/indicators and block diagramm constants should behave exactly the same when making changes to the type definition.
Regards, Jens
Actually, they don't behave the same if they are rings or combo boxes.
I stand corrected. Seems that I already lost my prize
Quote:
Thank you for this insight! Do you think this is the reason some of my controls are updating and some aren't? Im using Menu Rings used for VISA Resource addresses. Would making them **indicator's rather than controls in the type def solve the issue?
No, changing your typedef between control and indicator will not change the behaviour of rings or ring-like elements like VISA resource names.
But I'm puzzled on why you would have problems with your type-def cluster "AcqData". This contains only arrays, numbers and strings - unless you change the arraysize of an array (and hence its default value) inside your cluster type def.
Regards, Jens
Kudos are welcome...
