07-20-2010 02:00 AM
Hello!
We are working on a program that collects data from a DAQ and will post information to the user. The user will be able to choose from some different ways how the data should be presented. The main ide for this is to use subVI to process the data and have it displayed in a subpanel. Since the program is intended for human interaction only, we would like a nice looking menu and have created a sliding menu. When the user brings the mouse over the menu button there are alternatives sliding in from left. The alternatives are a bunch of controls grouped in a cluster. So far everything is fine.
The problem starts when the sliding part comes over a graph. In this case an update of the graph will position it in front of the cluster, resulting in part of the controls not being visible. This seems to only be happening when using the graph in a subpanel. Is there anyone else that has seen this problem and have a solution?
Please see the examplecode here for more information.
07-20-2010 01:43 PM
I can confirm this is still happening with LV 2010.
The obvious workaround would be to make sure the buttons don't intersect the graph. There might be some other options you can try, such as defering and undefering panel updates, but it's probably not worth the bother.
I reported this here.
07-21-2010 08:57 AM
Hi
I can also confirmed this, having bumped into it myself:
It only seems to happen, like you discovered, when you use subpanel controls and deal with objects that redraw a lot. I didn't find a solution to it and did as tst also suggested, made sure the tray never extends over the controls. Far from ideal and totally deserving a CAR. Will post the number when I created it (tomorrow)
Best Regards
David
NISW
07-22-2010 12:31 AM
Thank you both for your replies.
I will look into if it’s possible to rearrange controls and graphs so they don’t overlap in the project. If I find another solution I will post it.
07-22-2010 07:25 AM
CAR #241561
Best Regards
David
06-14-2011 07:08 AM
I can confirm that this issue is a problem since LV7.1 (maybe in earlier versions, too!)
Any solutions from NI site?
06-14-2011 08:44 AM
Hi EMG
The fix is still in work. When a new version of LabVIEW is released check if the CAR (se number in my previous post) is included in the ones fixed in the release.
Best Regards
David
