Can please anybody bring some light into position (and size) properties
of graph objects???
(Concerns Labview 6i (and probably also earlier versions).)
I do not understand the exact coordinate definition, especially for
graphs and its subobjects. It seems not straightforward, and I have the
impression that not all properties can be set.
You can set the position of the entire graph object, but not of the main
plot area. The effects of that depend on settings of subobjects (e.g.
legend etc.).
This has the effect that multiple application of the same values of the
properties led each time to a different result, which is at least
puzzeling. If I do not w
ant to call it a bug.
I see some ways to work around this, but it seems all unclear and
complicated to me. Also the documentation does not help me.
of graph objects???
Gilbert
P.S.: Since not everything is very easy to understand, I have attached a
nice and funny little example which sould make everything clear. Read
the VI description.
[See first answer for additional information]
