Good way to see what's in an array at a given time?
Sorry if dumb question, but I'm new to learning Labview and struggle to debug sometimes because I feel like I don't have a good grasp about how to see exactly what data is being transmitted through a given wire.
For example, I find that some built-in VIs will output an array when the only input was a double, so it would be extremely beneficial for my learning to understand exactly what is building the array and what is coming out of the VI. I can open up the VI's block diagram and try to make sense of the output array, but I feel like there must be an easier way to just open up the array to see what each element corresponds to.
I have a decent programming background mostly in Matlab, Python, and C++, so finding what indexes and elements build an array in, say, Python would be very straightforward, but I'm struggling replicating that same debugging ability in Labview. Would love to hear some recommendations from people!
Message 1 of 11
(488 Views)
crosspost from Reddit
Message 2 of 11
(485 Views)
Sounds like you want to probe the data
Or learn some debugging techniques.
Certified LabVIEW Architect
Message 3 of 11
(477 Views)
Thanks Gerd. I hate crossposts, but I was too quick.
Message 4 of 11
(476 Views)
Look at the wire.  It will have a color, possibly a texture, and a thickness.  This is not exhaustive, but should get you started --
Color:
  • Dark Blue = Integer (8, 16, 32, 64 bit, signed or unsigned)
  • Orange = Float (16, 32, 64 bit)
  • Green = Boolean (1 bit)
Texture:
  • A textured wire is often a "cluster", a mixture of various types, each with a name, similar to a Record in Pascal or a Struct in C.  Note that Object Oriented Programming "wires" are clusters.
  • A special Cluster, called the "Error Line", has a recognizable
  • coloring and texture.
Thickness:
  • Thin = scalar (e.g. a single value, such as 5, -3.1416, True, etc.
  • Thick = 1-D Array of whatever the underlying type is (e.g. Array of Dbl, Array of U32)
  • Pair of Thick = 2-D Array of whatever.
LabVIEW Code consists of Structures (such as While Loops, Case Statements, etc.), Functions (native to LabVIEW) and sub-VIs (code written by a Developer that "extends" the concept of a Function in that it transforms Inputs into Outputs).  A LabVIEW "program" is just the highest-level VI in a LabVIEW Project.
This should help you navigate around well-written LabVIEW code.  If it has "wires going everywhere" and looks like a mound of spaghetti, it may work, but it is not well-written LabVIEW code.  It it takes many monitors to see the entire VI, it is not well-written LabVIEW code.
Message 5 of 11
(423 Views)
in my old age, I sometimes misread things.  Your 2nd sentence made me laugh.
I realize that it means: It will have (color), (possibly a texture), and (thickness)
But I initially misread it as if it meant: It will have (color), possibly (texture and a thickness)
Message 6 of 11
(416 Views)
For array data, I typically use a probe that is a waveform graph.
(Too bad we cannot have two different probes on the same wire, so if we also want to see the array data, we could create a custom probe that shows a graph as well as a table.)
Message 7 of 11
(356 Views)
It didn't occur to me to try this until you said it, but you CAN make probes with splitters to show both an array and a graph. One of those things that's obvious in retrospect 😄
Message 8 of 11
(351 Views)
Of course a secondary question would be WHY can't we create two different probes on the same wire. I often want more than one view into the data and creating a custom probe takes efforts ....
Is there a fundamental reason or could this be an idea?
Message 9 of 11
(341 Views)
It is already- or at least was. Got auto-declined after too few votes:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Stacking-probes-on-a-single-wire/idi-p/1181631
(I think it would be cool if the probes could get overhauled. The "only runs when updated" limitation makes sense, but is frustrating. If NI open-sourced the probe window, you could get around the limitation by having probes that send data to a separate, always-running VI that hosts a bunch of QMH's to receive new data and process user interactions- a publish-subscribe approach seems like it'd work. You'd likely wind up making a bunch of data copies this way, but in my experience I don't have dozens of probes open at once, so the extra copies wouldn't affect me very frequently.)
Message 10 of 11
(333 Views)
