Global Variable issue
so when i run the project and run the main file until and i unless i click on data button the data doesn't load in file even though the data.vi is running in the background the data doesn't show  any dta if you open it without clicking on button i want the data to be shown when the main file is running Screenshot 2025-10-29 165820.pngScreenshot 2025-10-29 165831.png
Message 11 of 28
(385 Views)
  • You again failed to down-convert to LabVIEW 2020 before attaching.
  • You did not specify the name of the "main file"
  • Why use rar instead of zip? (true modern windows versions know how to open rar files, but with older version some might be out of luck)
Message 12 of 28
(355 Views)
main file is named main.vi inside project
Message 13 of 28
(339 Views)
I think you are missing some concepts.
Your data.vi is NOT running. It is ready to run, but not running in the background.
You call the vi in the event case for a button on you main.vi.
When your click on that button, the event will be fired, and the event case in the event structure will be executed.
In that case, your data.vi will be executed, but only at that time.
if you want a code to run in the background when you start your main.vi, then you need to program it to do so.
Message 14 of 28
(320 Views)
what is the best way to get the data, when main.vi is running and before executing it via button ?
Message 15 of 28
(316 Views)
Hi LaxTe,
Call the subVI once at initialization stage…
Message 16 of 28
(316 Views)
Nope that didn't worked as it open the vi any other way ?
Message 17 of 28
(255 Views)
Hi LaxTe,
What is "that"?
What is "it"?
What "opens the VI"?
What is "any other way"?
I really don't understand what you are writing…
Message 18 of 28
(252 Views)
That -  is your suggestion earlier didn't work,
it - the suggestion you suggested
when i put the subvi in main.vi it open the data.vi when i run it.
any other way -  any other suggestion you have better than that (your earlier suggestion) or can you help me by sharing the code with changes so it clarifies your earlier suggestion works, i am new to learning labview, kindly pls help
Message 19 of 28
(240 Views)
So you want functionality that is part of you data.vi ?
But you can't use your data.vi, as it is programmed, by you, to open it's front panel.
Why don't you make a new vi that has the function of reading data ?
Message 20 of 28
(236 Views)
