Joey,
A few questions:
Are you using an example program to read the temperature? If you have written your own code, you could have a bug in it.
Are you using the correct cold junction for the terminal block? If you select the wrong cold junction, it will give you the wrong reference temperature. If the cold junction temperature isn't displayed, check it with a probe.
Are you using the right units? Conversions between deg C and deg F can get you every time.
Are you using the right thermocouple type?
This should get you started...
Bruce
Bruce Ammons
Ammons Engineering
