Getting a pop-up "select a log file for vi xxxxx", how can I disable this?
Highlighted
Hi
I am getting a strange pop-up in my application which I suspect is associated with one of my sub-vi's.
The pop-up says "select a log file for vi save matrix data to file"  where save matrix data to file is oone of my sub vi's.
I would like to know how I can disable this pop-up (I can't understand why it asks for a log file at all).
I hope somebody can help
Many Thanks
Ash
Message 1 of 8
(5,631 Views)
Highlighted
Typically you get that when you open/read/write to a file and do not specify a filename.  Pretty much all of the file handling functions will ask for a filename if none is specified.  I am a little alarmed that your program would be attempting to access a file when you do not expect it too.  Can you post some of the code?  This sort of debugging can be difficult without knowing more about the application.
Message 2 of 8
(5,626 Views)
Highlighted
Well, such a popup is definitely not a default LabVIEW feature. You simply need to find out where it occurs, then recode.
To find the location, open the toplevel VI and do a "edit...find" as shown in the picture. That sould zero in on the problem area. 😄
Message Edited by altenbach on 07-27-2006 09:53 AM
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 3 of 8
(5,627 Views)
Highlighted
Actually, look at your settings in menu  "operate...Data logging...log". Anything interesting?
Message 4 of 8
(5,620 Views)
Highlighted
Thanks guys
I had a dattlogging option checked in two of my sub vis that format data to an ASCII file.
Fixed now.
Ash
Message 5 of 8
(5,598 Views)
Highlighted
 I went to "operate...Data logging...log", it caused the same popup that I get when I run my VI.  The "select a log file for XXX.vi" pop up.  How can I use this information to make that pop up stop popping up?
Message 6 of 8
(4,951 Views)
Highlighted
Until you select a log file, you'll keep getting the pop-up. Why would you select logging and then not select a file? The log at completion is such a rarely used option in the first place.
Message 7 of 8
(4,940 Views)
I wasn't trying to select log file, it must have been a fluke of a misclick.
After reading your comment I looked at the Operate dropdown menu and noticed a "✓" next to "Log at Completion", that's weird.  Smiley Frustrated
I'm not used to seeing select/deselect controls in dropdown menus.  I tried deselecting it, and then labview stopped asking for a log file.
Thanks for the assist 😄
Message 8 of 8
(4,903 Views)
