07-08-2005 06:51 PM
07-09-2005 03:14 PM
Ditto the PDA questions (and how about smartphones while we're at it?).
And what exactly does the PDA module do? Does it convert the LV code into C++ code? Why do you need to install eVC++ to build apps? And why do you need the source code for DLLs if you want to use them in your code?
How much has the LV codebase changed since it started (or how much remains with each new version)?
Are some of the primitives being rewritten\recompiled over time to be more efficient?
How efficient are the primitives? Or, to put it differently, why is it that when you open many VI.lib VIs you find CLF nodes?
How are bugs handled internally? What is the process in NI about identifying, verifing, documenting and fixing bugs?
And how about product suggestions? How do those get processed and decided upon?
07-10-2005 01:44 PM
07-10-2005 10:08 PM
Hi Christian,
I too have observed some intriguing behaviour when using property nodes and wish to discuss these with you.
Is there a thread that discusses in detail about property nodes?
If not, I shall start one. But how will I inform you which thread it is?
Best,
Gurdas
07-11-2005 09:50 AM
07-13-2005 07:46 AM
07-13-2005 03:36 PM
I Have a question about the ``Select Signals`` vi, it only allows you to choose between 8 signals, and not add any more. I need to display 128 signals all coming from one input, and its not enough for me, Do you have any idea how I can modify the select signals icon? or is there another icon I can use?
07-13-2005 03:42 PM
07-13-2005 03:46 PM
This is not the right thread for questions about Select Signals.
Select Signals only has 8 signals to pick from until it is run with a larger number of signals. Just run the VI once with your real data (or a set of simulated signals) that have more than 8 and then reconfigure it.
Hope that this helps,
Bob
07-19-2005 01:32 PM
