Get the count instance of LabVIEW Application
I am developing a LabVIEW application. Is it possible to get the instance count (so the first launched instance would be titled "instance 1", the second is "instance 2", and so on?
I guess this could be done using an event structure inside the main VI as a launcher and a counter to be passed to the VI. I was looking if there is a way to detect the current instance without creating a launcher.
KInd regards,
Waleed El-Badry, MSc., CLAD MCPD
(225 Views)
Your question is a bit vague. Are you talking about a single built applications that allows multiple instances? What do you mean by "titled"?
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
(197 Views)
My apology if it is vague.
What I meant is is it possible whenever I launch an instance of the application after deployment, I get an incremental number in the title?
KInd regards,
(179 Views)
Accepted by wbadry2
Yes, use a configuration file to hold a single integer and increment and save the value at startup.   Use the FP.Window.Title property to display something like "MyCoolApp %d"
"Should be" isn't "Is" -Jay
(164 Views)
