Get names from cluster variables
I have a cluster with a number of numeric variables which are bundled by names. The names and their associated values are now to be provided to a TDMS-file header via the "TDMS Set Properties" VI. This VI demands the names and values to be separated to the "Property names" and "Property values" inputs. My question is how to get the variable names out of the cluster to an array of strings?
I expect there will be a nice solution to this but I have not found this.
The suggestion in "Get Array Names from Cluster" from the community appear to be to adsvanced?
(7,400 Views)
If you know the structure of the cluster you can just supply an array constant with the names yourself?
If you do not know the names for some reason you could use a VI in the 'Open G' library called: -
Get Cluster Element Names__ogtk.vi
If you do not have Open G then a search on here should help you find a link to it
David
www.controlsoftwaresolutions.com
(7,396 Views)
Accepted by topic author skalis
Building on the OpenG suggestion, here's a snippet:
Ton
My LabVIEW Ideas
(7,368 Views)
This sounds too easy, but is this what you want?
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
(7,358 Views)
What is that block in PaulG's for loop and where can I find it!?
Thanks!
Joey
(6,142 Views)
That is a property node.  The simplest way to create one is to right-click on the control you want to set/get the property for and go to Create->Property and choose whichever property you want.
GCentral
(6,137 Views)
