Reply
Get digital input from a device to MyDAQ
Highlighted
Hi. I have a problem that I think should be easy, but I can't test it at the moment. Need to get it fixed quickly when set it up (long story). I have a motor that is giving a digital signal from when it's running and when it stops. I want to send that signal to a MyDAQ, so that my program takes measurements when the motor is running and stops when the motor stops. How should I configure my Daq-Assistant and the hardware. Is it enough to take the signal and plug it to one of the digital input signals? Or take the signal, plug it to a breadboard, connect a cabel to it from one of the digital inputs and digital ground?
Thank you
(879 Views)
Thank you
You just did not give enough details to help you. "I have a motor that is giving a digital signal from when it's running and when it stops." Do you know how many different models exist worldwide? Smiley Happy You should specify the model, and read its manual. That should give you the answer. It might be that you need to use a counter input of the MyDAQ device, but all depends on the signal coming from the motor. Does it give a quadrature encoder signal? Something else?
Since you did not detail this part, we cannot really help.
For a counter config, see this link: http://digital.ni.com/public.nsf/allkb/347064BB2D9F168686257760004F06BF
(851 Views)
