03-29-2018 04:57 AM
Thank you for your response
but I didn't understand how to use the point to row column method and how to wire it with the inputs that i have, in order to get the indexs of the listbox items in the array.
In the examples given, they have multiple MultiColumn Listboxes and they used an event case, which i think isn't necessary for my case!
Please, would you help me to use this method, because i have developed several other codes but they didn't work to have the expected indexs array, i have in almost of the cases (-1) which means that the listbox selected elements aren't found in the array
ThankYou
03-29-2018 05:22 AM
Hi.
see if this helps..
03-29-2018 07:01 AM
Thank you so much for your response, that helped me to understand how to use point to row column method, but doesn't respond exactly to what i want to do.
In fact, i have one column orders list and i want to know the rows indexs and the columns indexs of the selected orders in the big initial array as the VI that I attached previously, knowing that we access to this array it through a path file;
In your example it gives me the row-column indexs of a selected item in the listbox, however i want to know the row-column indexs of selected items of the listbox in another array according to the selected elements, to extract after that the data related to these items from these indexs.
03-29-2018 07:19 AM
hi samehA,
I can't open your VI, I am using LV2011..can you convert and post it again?
"however i want to know the row-column indexs of selected items of the listbox in another array according to the selected elements, to extract after that the data related to these items from these indexs."
I didn't fully understand this.
03-29-2018 07:39 AM
HI,
you will find attached the VI that i made converted to 8.0 version. In fact, i have two inputs, a listbox where there are many orders and a 2D string array.
My objective is to obtain the rows and columns of the selected items of the listbox in the 2D array, that means that i should have an an output, an array with 2 columns, one for the rows index and the second for the column index of the items selected in the listbox.
and then i should extract data from theses indexs ( obtain a 2D array where there are all the information related to the orders selected in the list box)
for the example attached here, if i select order 1 and order 24 in the listbox i must have a 2D array (line-column): { (5,0) ; (5,4) }, then have the values correspondant to these orders from this indexs array.
03-29-2018 07:45 AM - edited 03-29-2018 07:45 AM
My original VI searches the 2d Array for the data in the listbox (just for loop to find multiple) and will find the index (row and column) of that selection.
You are being confusing when talking about getting another 2D array... what do you need? do you need all the data thats in the column of the selection or the data thats on the row of the selection?
i.e.:
x, y, z
a, b, c
search for b >> it is in column 1, row 1. >> extract all data from column 1 >> output is y,b
OR
Search for b >> it is in column 1, row 1 >> extract all data from row 1 >> output it a,b,c
Please be clearer..
03-29-2018 07:54 AM
HI!
For the example that you gave:
x, y, z
a, b, c
I search for b >> it is in column 1, row 1. >> extract all data from column 1 >> output is y,b, ... ( the columns)
03-29-2018 07:56 AM
OK
So you'e been given the VI to get the row/column already..
just index or get array subset of the original array using the column...
03-29-2018 08:00 AM
The VI given is available only when you search for one element in an array , however i have a list box, it means that i can have many elements selected at once and i need to have all the columns indexs of these elements in the 2D array
03-29-2018 08:02 AM
The snippet we gave you here does exactly what you want...
