Get data from a 2D array following the elements selected in a menu ring
I have a 2D array of values ​​and I want to extract data from this array following the selection in the menu ring (this menu ring contains classes like this (class1, class3, class18, .... , class 100)).
For example, if I select classes 1, 3, and 100 from the menu ring, I want to have the corresponding 2D array data for those classes, that's why I have to look for the row and column indexs of (class1, class3, and class 100 ) in the 2D array, then, in a next step, extract data from the indexs that i have found.
PS: - I have to obtain the indexs of the rows and columns of the classes before because I will need them after for another data processing.
       - Each class is located in a different column in the 2D array.
I hope that i have express clearly my objective.
Do not hesitate to ask me questions and thank you in advance for your help.
Message 1 of 30
(3,710 Views)
I am not sure I totally understand your problem and your VI (or at least some data) would hepl.
However, you'll find attached a VI of what I get from your problem.
Hope it helps, do not hesitate to add more details if not 🙂
CLAMaxime -- Kudos are a great way to say thank you
Message 2 of 30
(3,690 Views)
Sameh
You can't select multiple items in a ring. Use a list box.
For searching You'll want something similar to the attached VI snippet (2017) but replacing the DBL with string likely. You can the index appropriately with the indices output...
This should get you started.
Cheers
J
Message 3 of 30
(3,688 Views)
Thank you for your response
In fact, i was wrong about the nomination, (my labview is in french),  it's not a menu ring but a list box where i can select multiple items at once and i need to have the indexs of the columns of all the items which i selected
Message 4 of 30
(3,681 Views)
Something like this ?
Message 5 of 30
(3,671 Views)
I didn't understand How did you find a 2D array as a result? I do the same as your code, but i found a 1D array
However, i must obtain a 2D array with 2 columns, one for the rows index and the second for the column index of the items selected in the list box.
and then i should extract data from theses indexs ( obtain a 2D array where there are all the information related to the classes selected in the list box)
Message 6 of 30
(3,664 Views)
Thank you for your proposed solution, it gives me the final 2D data array of the selected items in the list box, and that's good, but i need first to have the 2-column-array of the lines and columns indexs of theses items, and from it , i extract the datas in a second step.
My problem is that I didn't know how to obtain this indexs array  when i have mutiple items selected in the list box?
Message 7 of 30
(3,662 Views)
Can you provide us with an example VI please ? That would make it much more easier to understand what your inputs are 🙂
Message 8 of 30
(3,658 Views)
You find attached what i have done, As an input, i put a constant array analog to the file i'm working on.
I succeed to have the rows indexs by searching "NORMES" in the array , but for the columns indexs, i have as imputs a list box of the orders and the initial array,  so when i have more than one order selected, i have to get the indexs of the columns where there are these orders.
for the example attached here, if i select  order 1 and order 24 in the list box i must have a 2D array (line-column): { (5,0) ; (5,4) }, then have the values correspondant to these orders from this indexs array.
Thank you for your help.
Message 9 of 30
(3,629 Views)
hi samehA,
you need to use property called point to row-column, which gives you the row-column nos,
more info.
Point to rowpoint to row 2
bharath_p
LV2020
Message 10 of 30
(3,619 Views)
