Get application name via Windows API or another source
Highlighted
Here's a VI download as well... LV18.
EDIT: Saved back to LV11 as well...
Message 11 of 15
(129 Views)
Highlighted
What are all the 12345678 strings supposed to represent?
Message 12 of 15
(119 Views)
Highlighted
A buffer.
The dll needs a pointer to a buffer, large enough to copy the string in.
The string can't allocate the buffer, as it would be ambiguous who's responsible for releasing it.
Message 13 of 15
(117 Views)
Highlighted
Accepted by topic author Eric1977
Ah. Gotcha. Thank you for the explanation on some of those Windows API functions.
I wanted to share my solution in case someone else needs it. It was far simpler than what I realized which is usually the case after taking a step back.
After getting the Process ID (PID), I did a lookup on the task manager using the System Exec.vi looking for that specific PID and it will return the image name which is the executable name the application uses. Just throw that into an array and extract the ImageName. The VI uses LV 2018.
Message 14 of 15
(100 Views)
Highlighted
wiebe@CARYA wrote:
@Eric1977 wrote:
I can't seem to drag your image to a blank block diagram. It always comes in as a image.
That's because the forum shrinks the image to save bandwidth. In the shrinking process, it removes the embedded VI section.
  1. Copy the image's link:/t5/image/serverpage/image-id/272987iD312656E0CA750CC/image-size/large?v=1.0&px=999
  2. Remove /image-size...: /t5/image/serverpage/image-id/272987iD312656E0CA750CC
  3. Save this image.
Now it should have the embedded VI.
Anyway, I showed all names, so it could be replicated as well 😉.
Or:
  1. Click to image to start the image viewer
  2. Click the download button right below the image…
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 15 of 15
(95 Views)
