Get Windows accounts & users with LabVIEW
I would like to obtain the following information with LabVIEW :
- user account (admin or other) which is actually connected.
- user list and their own permission.
I don't want to use the "DOS CMD" but .net, windows dll or registry keys directly.
I use XP 32 bits.
How is it possible to get these informations?
Message 1 of 8
(2,235 Views)
Here is part of what you want.
The outer structure decides what OS it's on, you can delete that if you're only on Windows.
You create a 64-byte empty string and call a Windows DLL.
You get back the name of the logged-in user.
Look around for that DLL name - you might find what else is available.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 2 of 8
(2,221 Views)
You could use WMI to access this, the link below is not particularly suited to your requirement but by changing the search query (for example "Select * from Win32_UserAccount Where LocalAccount = True") and using Win32_UserAccount class members, you can get the necessary information.
http://forums.ni.com/t5/LabVIEW/How-to-access-WMI-Classes-via-NET-in-LabVIEW/m-p/286699#M150949
If you need help building the search query, you could use this: http://www.microsoft.com/en-gb/download/details.aspx?id=8572
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 3 of 8
(2,208 Views)
Thanks for the answer.
Indeed there are several methods to get username as yours.
You can get it as the screeshot or with the key registry.
Message 4 of 8
(2,191 Views)
Thanks also for the WMI which I didn't know before and which can be very useful and powerful.
Message 5 of 8
(2,190 Views)
Why not just use Application.Username?
Message 6 of 8
(2,181 Views)
--- Read the comment on my screenshot above.
Steve Bird
Culverson.com
Message 7 of 8
(2,177 Views)
Also you can access the active directories through .NET
The .NET 4.0 constructors have some real advantages over the 2.0 and 3.5 versions
Complete the following steps to force LabVIEW to load .NET 4.0 assemblies.
  1. Install the .NET Framework 4.0 on your development machine.
  2. Open a text editor and create a configuration file that contains the following text:
    <?xml version ="1.0"?>
    <configuration>
    <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v4.0.30319"/>
    </startup>
    </configuration>
  3. Save this new configuration file in the same directory as LabVIEW.exe. Name the file LabVIEW.exe.config.
  4. Relaunch LabVIEW.
"Should be" isn't "Is" -Jay
Message 8 of 8
(2,175 Views)
