Get LabVIEW.exe - No Disk message after diskette is removed
After my LabVIEW application reads in a file from a diskette and the user removes the diskette from the a: drive, I get the following message: "LabVIEW.exe - No disk. There is no disk in the drive. Please insert a disk into drive A:". After reading the file, my application closes the file, but LabVIEW still wants the floppy back in even though it is no longer reading the file. My application did not used to do this, but I recently started running this application on Windows 2000 (was Windows 95). Either that, or it is related to LabVIEW 7.0 somehow. What can I do to make this message go away?
Dave
(3,613 Views)
DO make sure that after you read the file from the diskette you will close the file opend by a close VI else you will get this message.
cheers
vicky
(3,595 Views)
Vicky,
I am doing the Close File VI after reading the file, but that does not fix this problem.
Dave
(3,586 Views)
hi would you post your VI or a simplified version of same so that we can have a look at it.
I use Labview 7
cheers
vicky
(3,581 Views)
Vicky,
I posted my VI. I open a file, read the file, and close the file. This has worked fine all along and I have not changed it. As I said, I think it has something to do with Windows 2000 (vs 95).
Dave
(3,566 Views)
Dave,
Sorry many sub vi's are missing,hey why dont u creat a .llb and also attach a .stp file as a single zip file to your next reply .
cheers
vicky
(3,554 Views)
