12-02-2025 10:02 AM
@wsimpson0050 wrote:
can you not use this?
Hi, I appreciate your willingness to help, but I think your comment is (a bit) off-topic.
Please read again all the previous comments carefully.
My initial post 1 year ago was to report a bug, which was filed to NI R&D thanks to Darren.
If I had to reformulate it today, it would be:
Function "Get Date/Time String" unexpectedly rounds to the nearest second when its input timestamp is unwired.
The expected behavior for a time display is obviously to always round down because it is more preferable to be a bit in the past than a bit in the future.
The workaround is then to wire the timestamp input or to use function "Format Date/Time String" instead.
Raphaël.
12-02-2025 11:03 AM - edited 12-02-2025 11:09 AM
Raphaël.
Perhaps there is a standard somewhere that says this, but I'd disagree with "obviously" there. I would have expected it to round in BOTH cases. I agree that the behavior you're seeing is a bug, because it should at the VERY least bet the SAME for both instances.
I'd argue that it should round like any other number. I don't see a reason it should be a bit in the past rather than closer to the "actual" time. Then again, I've never needed to think about time rounding until this very thread!
Edit: I thought a bit more about it, and I'm coming around... I think you'd apply the same logic to fractional seconds to seconds that you would seconds to minutes. If I had to round the time 7:45 and 20 seconds, that's clearly 7:45. 7:45 and 50 seconds is still 7:45; I wouldn't say it's 7:46 until ten more seconds passed. Same with hours and days... at 23:59 on December 2nd, I wouldn't round it to December 3rd.
So, I suppose you're right that truncating is likely the correct behavior for time. I think I'd argue that the help should mention this fact, though.
12-02-2025 11:15 AM
Raphaël.
Perhaps there is a standard somewhere that says this, but I'd disagree with "obviously" there. I would have expected it to round in BOTH cases.I agree that the behavior you're seeing is a bug, because it should at the VERY least bet the SAME for both instances.
Yes thanks, this is what I was struggling to explain.
12-02-2025 01:11 PM
Note that the two "Get Date/Time String" don't necessarily execute at the same time. They are very likely operating on different input values.
12-02-2025 01:17 PM
@Bob_Schor wrote:
This is NOT A BUG! It is a (poorly-documented?) Feature.
A TimeStamp is saved as a 128-bit quantity called an "Extended Precision Float". The high 64 bits represent the number of (whole) seconds since the 1904 (Unix?) Time-Zero base of the clock (needless to say, even earlier times are represented by negative numbers of seconds). The low 64 bits represent the fraction of a second on the clock. If you take the output of, say, Get Date/Time in Seconds and convert it to an Extended Precision Float, you will get a Float with a 10-digit integer part and about a 7-digit fractional part, while if you convert it to a U64, you'll just get the (same) 10-digit integer.
I'm "guessing" that "behind the scenes", LabVIEW only deals with the (numerically simpler and probably faster) high 64 (integer) bits unless the user specifically asks for "fractions of a second" (which requires delving into the low 64 bits + the "sign" bit in case of Date/Times before 1904). So the "rounding rule" (possibly poorly-documented) is "If the user is only counting seconds and not fractions of seconds, use an Integer format, but if fractions of a second are specified (for example, with the %u format string), use the full 128-bit (unique?) Time/Stamp representation and the usual Float Rounding Rules".
Don't get me started with the Excel Variation on this topic. About a decade ago, I figured it out "by experimentation" for myself, but I haven't thought about it in "about a decade" since then. As I recall, Time Stamp, LabVIEW, and Excel came up before in the Forum -- I'm too
lazybusy to try to find it all ...
Note that while extended precision numbers occupy 128 bits, they only use 80 (and are often only accurate to 64 bits). 48 bits are always 0s.
